SYSTEM INFORMATION | |
Ubuntu server 20;.04 running on a OpenVZ VPS.
Virtualmin 6.17-3
This is a new install.
I went to Webmin/Networking/FirewallD and attempted to add an allowed port. It showed up in the rules list so I pressed the “apply” button. I say apply 'cause I don’t recall the exact name.
Now there are no rules listed and iptables -L gives me the basics,
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
So I attempted to add it again and see what happens, firewallD isn’t running so to button now reads Start FirewallD. When I press it, it just refreshes the screen and a systemctl status firewalld returns:
Jan 20 18:57:20 linux.2a6055.com systemd[1]: Starting firewalld - dynamic firewall daemon...
Jan 20 18:57:21 linux.2a6055.com systemd[1]: Started firewalld - dynamic firewall daemon.
Jan 20 18:59:45 linux.2a6055.com firewalld[39304]: WARNING: ALREADY_ENABLED: 'ssh' already in 'public'
Jan 20 18:59:46 linux.2a6055.com firewalld[39304]: WARNING: ALREADY_ENABLED: ssh
Jan 20 19:00:08 linux.2a6055.com firewalld[39304]: WARNING: ZONE_ALREADY_SET: public
Jan 20 19:40:15 linux.2a6055.com firewalld[39304]: WARNING: ALREADY_ENABLED: ssh
Jan 20 19:41:38 linux.2a6055.com firewalld[39304]: ERROR: '/usr/sbin/ebtables-restore --noflush' failed: ebtables-restore v1.8.4 (nf_tables):
line 3: CHAIN_USER_DEL failed (Device or resource busy): chain PREROUTING_direct
line 3: CHAIN_USER_DEL failed (Device or resource busy): chain POSTROUTING_direct
line 3: CHAIN_USER_DEL failed (Device or resource busy): chain OUTPUT_direct
line 7: CHAIN_USER_DEL failed (Device or resource busy): chain INPUT_direct
line 7: CHAIN_USER_DEL failed (Device or resource busy): chain OUTPUT_direct
I omitted the first few lines.
It doesn’t like like firewalld is ready for prime time. SHould I disable firwalld and install ufw? Or maybe go back to plain vanilla iptables?
I also observed that the FirewallBackend in the config file is iptables. However the above error message refers to nf_tables.
Thanks,
Jim.
