How to fix this Laravel 403 Forbidden Permission to access Error in my case?
I just made a remark… It works when I run in my browser the link without the https (http://msg.mydomain.com/), it works fine. But the problem of the error 403 Forbidden You don’t have permission to access this resource reappears.
So the problem is in the HTTPS and HTTP protocol.
Why then, HTTPS (https://msg.mydomain.com/) does not work unlike https://msg.mydomain.com/public which works well ???
And on the other hand, why does HTTP without SSL security (http://msg.mydomain.com/) seem to work ???
Please help me fix this as I think this is where the problem lies.
Where it says Select Redirect Type - put that on permanent
Where it says include sub paths in redirect - select yes.
See if that sorts it. I don’t know what this software you’re using is for, but it sure as hell is problematic.
