So this machine is using LVM as the filesystem, but, apparently, the default is not virtio as in cloudmin under Edit System -> Advanced KVM settings, it says the KVM disk driver is IDE. So, I suppose I should enable that in cloudmin settings as the default.
But for existing machines, can this be changed via Cloudmin? If so, how?
