One of my machines does not appear to have quotas enabled.
How would I enable quotas in the manner typical of Virtualmin’s default configuration.
Thanks,
Tony
Thanks,
Tony
Webmin->System->Disk and Network Filesystems
Click on the filesystem that contains /home (could be /home, could be / (root filesystem)).
Set "Use Quotas?" to User and Group.
Save it.
Webmin->System->Disk Quotas
Enable quotas on the previously configured filesystem.
Reboot or remount filesystem (if it’s the / system you’ll probably need to reboot…also if you use something other than Linux, since only Linux seems to be able to remount active filesystems to enable quotas, as far as I know).
On Linux the following usually works:
mount -o remount /
If it fails, you’ll have to reboot.
Thanks. That did it.
