How to disable ssh for virtual servers
I must be blind but I can’t find the option anywhere.
When I create a new virtual server the default user has Mail, FTP and SSH access. I want the user to have only FTP and Mail access, no SSH. Where do I change it in the server template? Or anywhere. I can’t seem to find the option…
it has been said the /etc/shells file should have /bin/false on the first line so new users get that permission instead of /bin/sh
However after i did this users still get sh and I change that manually under webmins module Users and Groups.
I have never seen an option in the Server Template, but would also like to know how to restrict the new users as I don’t usually give ssh to users.
There is now a form for managing shells for all types of users. Look in System Customization:Custom Shells
We need to get that page better documented. It looks more intimidating than it actually is. :wink:
Yes, I’ve found the custom shells page before, but where do I select the type of access that newly created users will have by default? I think it should be somewhere in server template but it isn’t.
And I can’t edit my post here, “Oops! You’ve hit a bug in the forum software. It’ll be fixed soon.” :D:D:D
Anyway, I think it would be a good idea to place the option in server template -> default domain owner limits.
Now I have to change this after I create the virtual server, a bit tiresome :wink:
Joe
I got no clue what to do in there and which domains it would affect.
However by looking at that module again, I realized I could integrate my ticket system into virtualmin, and the site where one can upgrade the package. hehe yay!
I created a category "support" but it would be nice to add custom links to existing categories, like in my case services.
OK I found out how this works.
in the system customisation I have enabled
now servers created have a default of /bin/false
It would however still be preferred to have the option in the server template as some plans might have shell where others might have only FTP
I also faced this problem…and didn’t find a way to solve it.
I also found the Custom Shells Page…it was the scariest page I found in Virtualmin (GPL) :smiley:
This is what I did, I went to: SSH Server -> Access Control, at the option "Only allow users" I placed the name of a user account I created, so only that user was able to login.
As another security precaution I went to: SSH Server -> Authentication, at the option "Allow login by root?" I selected NO, so only the user I specified was ablte to login (but after I think of it, only the "Access Control" option should work also…).
After that I went to: SSH Server -> Networking, at the option “Listen on addresses” I added the IP Address I want the server to listen on, it’s the same IP Address I use as a ‘Management Network’.
When a user tries to login on my server(s) using SSH, it closes the connection after a few failed login attempts, but I cannot remember if that was a standard feature (CentOS v5.1) or something standard :smiley:
Molski
I’m also looking at how to use the Custom Shells section. I’d like to disable ssh and ftp as default for virtual server users and keep it just for my admin/root user… Any ideas how to do this?
In the Custom Shells screen, what you’d want to do is ensure that no user has “/bin/bash” or “/bin/sh” as a shell.
You’d only want /bin/false, or /dev/null. A user with /bin/false can log into FTP and email, a user with /dev/null can log into just email.
