I am beginning to play with node.js for a site or two: I found the node.js installer for the pro version, and I see it running with the associated account.
What I can’t see is how to modify what node loads, or most importantly how to restart node properly without being root. (send a signal?)
I CAN figure out the appropriate virtualmin commands, but it requires user root.
Are there virtualmin gui controls for:
what javascript files (server.js by default on port 3000) get loaded up by node?
what port numbers are chosen?
installing other npm packages?
how to reload server.js
I can do all of it as root at the command line. I can even do some of it as the virtual server's username (edit server.js, install npm packages...)
I would love to hear how it’s done by the rest of you…
Currently node support is pretty limited, but I’ve started doing Node development, myself, and I see a lot of low-hanging fruit we can develop to make the experience nicer.
So, no, there’s no GUI support for any of those, except restarting the server, which I believe should appear on the Install Script page (at least, Django and RoR have restart buttons, and I assume node is no different).
I’ll have to spend some time with it before I actually know how Jamie has done some of the stuff, and will have to read some code. But, suggestions and requests are welcome. It’s an area where I want to spend some time now that Virtualmin 6 is out the door.
