How to change post-installation settings
After virtualmin installation, I set in the wizard:
[NO] Run ClamAV server scanner
[NO] Run SpamAssassin server scanner
I would like to revert these choices to [YES] as the CPU and RAM load is heavy for each process execution.
How can I change this ?
Yann Papouin.
It’s Ok now, I found the right way to do this:
Virtualmin > Email Messages > Spam and Virus Scanning
  • Enable both servers
  • Select spamc (Client for SpamAssassin filter server spamd) for SpamAssassin client program
  • Select Server scanner (clamdscan) for Virus scanning program
  • Save
Yup, that’s exactly it… I’m glad you figured it out!
