I created new instance by using remote api but i used parameters for memory, disk space, cpu etc…
My doubt is how to use created plan in remote api for create-system. It is very use full to me for update host. Thanks in advance.
Good question…I’m talking to Jamie about it via email. Will find out and get back to you.
If it’s not possible today, it likely will be soon. We tend to want everything in the GUI to also be in the API.
