Hey Eric sorry I had to make this one private again
I bought the one we was on about on the other post
I followed the docs link you sent me
http://www.virtualmin.com/documentation/tutorial/how-to-add-an-ssl-certificate
Looking at the Docs number ‘2-4’
I didn’t get a IP with the SSL Cert?
Also looking at number ‘19’ I didn’t get any codes from the cert all I got was a Zip file with two items in it
www_domain_com.ca-bundle
and a
www_domain_com.crt
(I renamed the domain part as belive me you don’t want to know the name of this sick site :D)
Cheers
edit = I think ive done it Eric!
http://i.imgur.com/0IKVV7N.jpg does this look right Eric?
Also about the email using this if I click these
Use this certificate in Dovecot for SSL-protected IMAP and POP3 connections.
Use this certificate in Postfix for SSL-protected SMTP connections by mail clients.
Will it only be on this domain>? not on all the others or is this like a ‘push to all settings one?’
Thanks again!
