How do I install it on a Solaris system?
The list os supported OS’s are here:
http://www.virtualmin.com/os-support.html
Unfortunately, if you’re using Virtualmin GPL, Solaris isn’t supported at this time.
If you’re using Pro, you’d just want to use the Solaris-based installer. You can find it at virtualmin.cm/serial/ – and just click the “Solaris” download link.
