SYSTEM INFORMATION | |
OS type and version | REQUIRED |
Webmin version | REQUIRED |
Virtualmin version | REQUIRED |
Related packages | SUGGESTED |
How can I upload a project of node js + express + SSL step by step?
This is not a Virtualmin question. We are not nodejs+express experts. You deploy nodejs on a Virtualmin system in the exact same way you would for any system: You proxy to the nodejs app server on a local port or socket.
SSL, on the other hand, we do support. You just need to enable it and request a free certificate from Let’s Encrypt. The GUI is extremely simple to use, but if you have any problems, you’re welcome to post further questions about that.
