When I set in Virtualmin -> Webmin -> Networking -> Network Configuration -> Hostname and DNS Client, Hostname name with dot and something after, it won’t showup in box after saving it.
ex. I set example.com it will only shows example (without dot and after).
but in Virtualmin’s System Information, System hostname is providing name right, with dot (example.com).
As for the 127.0.1.1 thing, Debian/Ubuntu have started doing this to deal with a reality of mostly dynamic IP addresses…but it’s a funky solution to the problem, with some odd side effects. Anyway, in a server, you want a regular static IP (even if it’s just a private one, like 192.168.1.1) and not a second lo address.
My server’s IP is static.
I have changed my /etc/hosts/ with:
[code:1]192.168.0.1 example-domain.com example-domain[/code:1]
but problem still remains (hostname without dot and after in panel).
When I type hostname, it’s the same like hostname -f, and it just shows example-domain.com.
My domain is with dash in name, maybe it’s the problem?
I show you the rest of hostname commands: uname -n -> example-domain.com hostname -a -> example-domain hostname -s -> example-domain hostname -d -> com hostname -f -> example-domain.com hostname -> example-domain.com
This is actually a bug in Webmin 1.480 - on that Hostname and DNS Client page, it always shows the short hostname. However, it will save whatever fully-qualified hostname you enter.
