So I’m hosting myself from home (localhost) and can access the admin site from home via ipaddress:10000. When I’m outside of my network, the sites work fine typing in the domain names. What I can’t seem to do is access the main site to test it while I’m on the same network. I’m only able to access the last domain that I created if I type in the ip address, but not the main system hostname domain. Typing in the domain name only brings me to my router (which is 192.168.0.1). I thought there would be a little trick like ipaddress/~domainname, but that is not working.
Thanks.
Try to edit Apache VirtualHost related entries and make them all listen on *:80 rather than IP:80. Virtualmin has a configurable option Always use * for Address format for Apache virtual hosts under Defaults for new domains on System Settings > Virtualmin Configuration page.
Thanks. tried this and then input my domain and same thing…maybe I will reboot server to see if that changes things. Thanks for the help.
Consumer routers rarely support access to the public IP from the local network.
It’s a tricky bit. I have made it work, but I’m not sure how probably because I have listed servers Ip as DMZ on the router. But idea is that that this usually doesn’t work with a home router, I don’t know in detail why, but in reality, when you call to DNS you redirected to your own personal router from public side and there is a confusion for router. Simply append your PC /host file with static maping
192.168.0.123 www.yoursupperweb.com
then PC wont even asks DNS and will go stright to server address.
