Hi.
I installed Horde and Well … how do you login as administrator in it ?
Faisal.
Hi.
Faisal.
Let me explain.
After installation First Time the administrator login should be logged in by default. But this does not happen. Any idea why ?
Ok Figured this out.
IN the
horde/config/conf.php
The following Line needs to be changed :
$conf[[‘auth’]][[‘admins’]] = array(‘Administrator’);
To have the value of Administrator as probably the username. So that Authentication as Admin is allowed. This is important also because After the default installation the administrtor login doesnt work without it.
Thanks.
Faisal.
