Hello.
It’s the irst time that i use Virtualmin, I’m a newbie but i ask for help only because i tried many solutions for my issue and i have always the same thing.
I really hop that someone can help me here.
I have (Debian 6.0 LAMP - 64 bit) as OS.
And here is the configuration of my Deticated Server :
Intel® Core™ i7-2600 Quadcore
RAM 32 GB DDR3 RAM
Hard disks 2 x 3 TB SATA 6 Gb/s HDD
7200 rpm (Software-RAID 1)
NIC 1 Gbit OnBoard
connected at 100 Mbit
I installed Virtualmin as clean install (new installed OS) and i only add PhpMyadmin latest version.
Everything work fine and even it’s the first time for me with virtualmin i did not have any problem with the configuration.
The issue is :
When i try to import files by PhpMyAdmin (.sql files with 730K size each) i got the error (in log errors)
PHP Fatal error: Allowed memory size of 33554432 bytes exhausted
And when i run (top) the memory is only at 0.1% BUT the CPU usage is at 100% and remain like that
So i changed the ‘memory_limit’ in files :
/etc/php5/apache2/php.ini
/etc/php5/cli/php.ini
/etc/php5/cgi/php.ini
I increase until 1024M.
Now i get the ‘timeout’ warning message and still my databse not imported, and evrey time i try to import again the PhpMyAdmin page remain loading then i get a blank page, and during the operation the CPU is at 100% when i run the ‘top’ command.
Did i miss something ?
Did my hosting provider the cause ?
Please, I’m waiting some advices
Waiting for your answers.
Best Regards.
