ok im running ubuntu 8.04 and virtualmin pro with latest updates on everything. it was installed on fresh os install using the install string on my perchase page. but no matter what i seem to do i cant get mail in or out and when i try to setup outlook express i always get error trying to check mail.
There was a problem logging onto your mail server. Your Password was rejected. Account: 'mail.xxxxxxx.com', Server: 'mail.xxxxxxx.com', Protocol: POP3, Server Response: '-ERR Login failed.', Port: 110, Secure(SSL): No, Server Error: 0x800CCC90, Error Number: 0x800CCC92
It sounds like your ISP probably blocks outgoing port 25.
Your options are:
Use your ISP’s SMTP server as a mail relay, rather than attempting to connect to your Virtualmin server for sending email.
Enable SMTPS and/or Submission within Postfix, and connect to your server on port 465 or 587. You’d enable those by logging into Virtualmin, and clicking Webmin -> Servers -> Postfix -> SMTP Authentication And Encryption, and making sure “Enable SASL SMTP authentication” and “Enable TLS encryption” are enabled, then restart Postfix.
Feb 5 22:21:32 ubuntu postfix/smtpd[1749]: fatal: parameter "smtpd_recipient_restrictions": specify at least one working instance of: check_relay_domains, reject_unauth_destination, reject, defer or defer_if_permit
Feb 5 22:21:33 ubuntu postfix/master[28487]: warning: process /usr/lib/postfix/smtpd pid 1749 exit status 1
Feb 5 22:21:33 ubuntu postfix/master[28487]: warning: /usr/lib/postfix/smtpd: bad command startup – throttling
Or you could email me your root login details to eric@virtualmin.com – if you do that, be sure to include a link to this forum thread in the message body.
Also note that there are two topics going on in this thread…One of which is sending mail through your server using a mail client (which would involve Postfix), and the other is retrieving mail via POP or IMAP (which would involve Dovecot). Keeping the two problems separate is probably wise, since you wouldn’t want to be chasing a Dovecot problem by sending mail, or chasing a Postfix problem by retrieving mail.
