Yes, telnet results are same as several weeks ago with connection.
Port 143.
Trying 192.168.1.163...
Connected to 192.168.1.163.
Escape character is '^]'.
* OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE STARTTLS AUTH=PLAIN AUTH=LOGIN] Dovecot ready.
Port 993.
iptables -L -n shows all ports are open
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:20
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:21
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:53
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:20000
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:10000
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:993
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:143
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:995
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:110
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:21
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:587
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:25
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 state NEW tcp dpt:22
REJECT all -- 0.0.0.0/0 0.0.0.0/0 reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
/etc/postfix/master.cf file has details below:
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master").
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
#submission inet n - n - - smtpd
# -o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_client_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
smtps inet n - n - - smtpd -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes -o smtpd_client_restrictions=permit_sasl_authenticated,reject -o milter_macro_daemon_name=ORIGINATING
#628 inet n - n - - qmqpd
pickup fifo n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
# When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - n - - smtp
-o smtp_fallback_relay=
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
#maildrop unix - n n - - pipe
# flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
# The Cyrus deliver program has changed incompatibly, multiple times.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user}
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
#uucp unix - n n - - pipe
# flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
#ifmail unix - n n - - pipe
# flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
#bsmtp unix - n n - - pipe
# flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
#scalemail-backend unix - n n - 2 pipe
# flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store
# ${nexthop} ${user} ${extension}
#mailman unix - n n - - pipe
# flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
submission inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
The maillog gives 12000 lines of similar looking errors like this sample:
(also, I don’t know who those email addresses are as I don’t know any of them? Seem to have been automatically generated).
Dec 17 16:14:21 localhost postfix/error[18758]: B4BE01373B: to=<teetsfxwy@hotmail.com>, relay=none, delay=326867, delays=326846/21/0/0.02, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18755]: B25EC134B1: to=<ugaldetpsad@hotmail.com>, relay=none, delay=327770, delays=327750/21/0/0, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18758]: B47E813751: to=<bennoleco@hotmail.com>, relay=none, delay=325065, delays=325045/21/0/0, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18756]: B1A09136E6: to=<apoilkospa@hotmail.com>, relay=none, delay=426070, delays=426050/21/0/0.02, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18760]: B532C13717: to=<nanaswndf@hotmail.com>, relay=none, delay=424222, delays=424201/21/0/0.02, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18758]: B8BEC13740: to=<deweydnjfc@hotmail.com>, relay=none, delay=325967, delays=325946/21/0/0, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18755]: BE46F1375A: to=<lisletvo@hotmail.com>, relay=none, delay=325064, delays=325043/21/0/0.01, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18755]: 89E3B1370A: to=<naparta3975@gmail.com>, relay=none, delay=425769, delays=425748/21/0/0, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=gmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18756]: B328213724: to=<searbyly@hotmail.com>, relay=none, delay=424219, delays=424198/21/0/0.02, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:14:21 localhost postfix/error[18760]: B4BBE136F4: to=<carrolnmejh@hotmail.com>, relay=none, delay=426069, delays=426048/21/0/0.01, dsn=4.4.3, status=deferred (delivery temporarily suspended: Host or domain name not found. Name service error for name=hotmail.com type=MX: Host not found, try again)
Dec 17 16:20:11 localhost dovecot: imap-login: Login: user=<myEmail@domain.com>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=18983, secured
Dec 17 16:20:12 localhost dovecot: imap(myEmail@domain.com): Connection closed bytes=1083/42562
Dec 17 16:20:16 localhost dovecot: imap-login: Login: user=<myEmail@domain.com>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=19001, secured
Dec 17 16:20:16 localhost dovecot: imap-login: Login: user=<myEmail@domain.com>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=19003, secured
Dec 17 16:20:17 localhost dovecot: imap(myEmail@domain.com): Connection closed bytes=1083/42562
Dec 17 16:20:17 localhost dovecot: imap(myEmail@domain.com): Connection closed bytes=408/3282
