I need some help with setting up the networking on a Centos 6 host using kvm - I can’t get the networking set up correctly - I ran the installer and it finished successfully, and double checking the settings all appears correct as suggested in the documentation.
However for some reason the bridging is failing to allow access to the LAN.
this is what I commented out:
NAME=“System eth0”
NM_CONTROLLED=yes
HWADDR=98:4B:E1:10:2B:A6
TYPE=Ethernet
PREFIX=24
DEVICE=eth0
BRIDGE=br0
DEFROUTE=yes
IPV4_FAILURE_FATAL=yes
DNS1=192.168.128.1
ONBOOT=yes
#UUID=5fb06bd0-0bb0-7ffb-45f1-d6edd65f3e03
Although I now have a problem whereby Cloudmin doesnt want to acknowledge connectivity, for example when trying to upgrade webmin:
