In regards to virtualmin, im a newb, but with linux, im a moderately(5 out of 10) knowledgeable user
Now, i know that to some extent that this is a postfix question, but the reason i ask here is because i dont know what this means
A problem was found with your Postfix virtual maps : No map sources were found in the Postfix configuration
there are multiple areas for mappings in the postfix configuration and i dont know which one, i also dont know at all what a postfix map is, or what they look like. i dont even know the file extension.
If you need me to clarify anything, i can, the reason this looks so bad grammatically is because its late.
but i just want a pointer, what to do, maybe a little walkthrough, and this topic getting stickied for future users.
I have experimented with virtualmin 2 times, and each time i have come accross this same problems, so i am very greatfull for all the help that can be given.
I’ve commented out the original virtual_alias_maps line (it was the same as Caribooredneck) and added your recommended line and get the same results…
'A problem was found with your Postfix virtual maps : No map sources were found in the Postfix configuration
… your system is not ready for use by Virtualmin."
What else can you suggest?
Thanks,
Dana
Edit: As I read further I found that Virtualmin on Ubuntu 9.10 is not actually supported but is on the 8.04 LTS. So I am starting over with the LTS and the install.sh. Thanks, Dana
