Help with new (first ever) install please
hiya,
i’m trying to install onto a Ubuntu 64bit server 10.
ive used both this:
wget -O install.sh http://software.virtualmin.com/cgi-bin/install.cgi?serial=SERIAL&key=KEY; /bin/sh install.sh
and this:
sh ./install.sh
but i get the same message in the installation log:
INFO - 2011-05-14 15:47:00 - Started installation log in /root/virtualmin-install.log
DEBUG - 2011-05-14 15:47:00 - Install mode: full
DEBUG - 2011-05-14 15:47:00 - Product: Virtualmin Professional
DEBUG - 2011-05-14 15:47:00 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2011-05-14 15:47:00 - install.sh version: 1.0.5
INFO - 2011-05-14 15:47:00 - Checking for fully qualified hostname…
INFO - 2011-05-14 15:47:00 - Hostname OK: fully qualified as XXXXXXXXXXXX.co.uk
INFO - 2011-05-14 15:47:00 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2011-05-14 15:47:00 - Loading OS selection library…
INFO - 2011-05-14 15:47:01 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2011-05-14 15:47:01 - Loading OS list…
INFO - 2011-05-14 15:47:01 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2011-05-14 15:47:01 - Operating system name: Ubuntu Linux
INFO - 2011-05-14 15:47:01 - Operating system version: 10.10
INFO - 2011-05-14 15:47:01 - Configuring package manager for Ubuntu Linux 10.10…
INFO - 2011-05-14 15:47:02 - Enabling universe repositories, if not already available…
INFO - 2011-05-14 15:47:02 - Disabling cdrom repositories…
INFO - 2011-05-14 15:47:02 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2011-05-14 15:47:02 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2011-05-14 15:47:03 - Installing Webmin and Virtualmin package signing keys…
INFO - 2011-05-14 15:47:03 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2011-05-14 15:47:04 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2011-05-14 15:47:04 - OK
INFO - 2011-05-14 15:47:04 - Hit
INFO - 2011-05-14 15:47:04 - Removing Debian standard Webmin package, if they exist…
INFO - 2011-05-14 15:47:04 - Removing Debian apache packages…
DEBUG - 2011-05-14 15:47:04 - Reading
INFO - 2011-05-14 15:47:04 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip quota
Reading package lists…
Building dependency tree…
Reading state information…
FATAL - 2011-05-14 15:47:06 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2011-05-14 15:47:06 - Cannot continue installation.
FATAL - 2011-05-14 15:47:06 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2011-05-14 15:47:06 - re-attempted after any problems have been resolved.
FATAL - 2011-05-14 15:47:06 - Removing temporary directory and files.
FATAL - 2011-05-14 15:47:06 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2011-05-14 15:47:06 - in /root/virtualmin-install.log
it doesnt really tell me where to start looking as the readout from the CLI is the same as whats on the installation log.
anyone got any ideas?
thanks
zac
From the output above, it looks like you’re using Ubuntu 10.10.
Unfortunately, that’s not one of the distro versions the installer supports… you may want to try the Ubuntu LTS release, 10.04.
You can see a list of supported distros here:
http://www.virtualmin.com/os-support.html
hi, thanks for getting back.
yep sorry, i missed that. I have now installed 10.04 version.
this time i didnt bother to install a gui some i’m doing this from the CL
i downloaded the VM install file using this:
that went fine
then i tried to install sing this:
sh ./install.sh
but i get exactly the same error message as above.
P.S. when installing 10.04 from the disk a chose not to install any packages like dns, apache, mysql etc etc so this is a total blank install.
what can i try next please?
thanks
zac
sorry, update…
just readin through the install log thats on the screen, the last entry before the fatal error is:
“Package Webmin is not available; but is refered to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source”
does the routine that i listed above for installing VM not by defualt include the downloading/installing of webmin?
thanks
zac
Can you attach the /root/virtualmin-install.log file for your new installation? It will hopefully contain some details about what’s going on. Thanks!
i’m not sure i can get the log file off the server and onto my laptop to attach it.
i guess if i install a gui on the server i could but how else?
There’s a few different ways to grab that… one would be to use scp. If your desktop is Windows, WinSCP would allow you log into your server using scp and download that file.
because of my lack of knowledge using the CLI i’ll bever be able to install and configure a ftp server without using a gui.
i’ll have to install one quickly and grab the file.
The SCP protocol works over SSH, which should already be installed and working on your server.
So, if you install WinSCP on your desktop, you can log into your server as root and transfer files.
a ha, ssh wasnt installed so i installed it and started it and scp connected straight away. thanks for that… learning all the time!
please see pic attached. for some reason the virtualmin-install.log does not exist
pic
The file you’re looking for is “/root/virtualmin-install.log”, which means it’d be in the “/root” directory.
sorry, i was thinking that root was infact THE ROOT for example like a web root, not an actual name of a dir, silly mistake.
please see log:
Hmm, well, it looks like it doesn’t like something about your software repositories, though I’m not quite sure why ATM.
Could you attach the install.sh script that you’re using to perform the installation, as well as your /etc/apt/sources file?
That should help in determining what’s going on there.
Thanks!
Also, I marked this post as private, so no one will be able to see your serial number / license key that’s embedded into the install.sh script.
cool thanks for doing that. i didnt even thinking about removing that info.
here are the files requested.
zac
cant upload the sources file because the forum only allows jpg jpeg gif png txt doc xls pdf ppt pps odt ods odp svg
i’ll just try a zip… hang on…
you want the dir right? or just one of those individual files?
For now, just the sources.list file.
You can rename it to sources.list.txt in order to attach it to your post.
sources.list
