I’m trying to determine memory usage on my dedicated server, as I think that Virtualmin GPL is potentially getting it wrong, but maybe its just the way I’m interpreting the values given.
When I load into Virtualmin GPL I can see this: Real memory 7.90 GB total, 324.06 MB used
However when I run ‘top’, I get this: Mem: 8287684k total, 2013560k used, 6274124k free, 105308k buffers
Is Virtualmin reporting back an incorrect figure, or does ‘top’ take into account other services that Virtualmin isnt?
Aha! I had almost forgotten about this, but I believe what they’re doing is accounting for buffers/cache in those calculations.
From what I understand, both buffers and cache imply a temporary usage of memory – only up until the point when the Linux kernel realizes it’s needed for something else.
So technically, memory reported in buffers/cache is actually “free” – Linux is just making temporary use of it while it’s sitting there not doing anything.
If you take the memory used as provided by “free”, then subtract that shown in both buffers and cache, you get a number very similar to what Virtualmin is showing there.
Ah yes, I understand. I’m only really questioning as I’m trying to determine the source of a potential memory leak, and I noticed that the values weren’t correlating.
