Help with GPL version
I have installed Cloudmin GPL on citrix xenserver 6.2 I am getting This system cannot be a Xen host : The required command xm does not exist. Perhaps the Xen software is not installed?
Virtual systems cannot be created or added until this is fixed.
Please help.
Partha
Unfortunately, I don’t believe Cloudmin GPL supports Citrix Xen as a host system for VPS’s. There’s some details here that describe using it with Cloudmin Pro:
https://www.virtualmin.com/documentation/cloudmin/virtualization/citrix
If you were to use a standard Linux distro using the distro’s own Xen capabilities, that would indeed work though.
oh no!!
will it support ESXI5 the pro version too?
Nope, Cloudmin doesn’t support VMware. Only the systems listed here:
http://www.virtualmin.com/about-cloudmin
