Hi!
I´m new to this forum. I´ve redently got a dedicated server and installes Centos 7 with Virtualmin to server a few WEbsites that I have.
Install was pretty easy and now I can say that I have Virtualmin near production, so I can migrate all sites.
But I have a problema with my mails:
- ClamAV had trouble and I found some solutions in this forum that a I´ve aplied.
ClamAV is running:
[root@srv1 mail]# systemctl status clamd@scan
● clamd@scan.service - Generic clamav scanner daemon
Loaded: loaded (/usr/lib/systemd/system/clamd@scan.service; enabled; vendor preset: disabled)
Active: active (running) since Di 2016-11-29 18:14:39 BRST; 32min ago
Main PID: 2639 (clamd)
CGroup: /system.slice/system-clamd.slice/clamd@scan.service
└─2639 /usr/sbin/clamd -c /etc/clamd.d/scan.conf --foreground=yes
Nov 29 18:14:46 srv1.loewenhaupt.com.br clamd[2639]: HTML support enabled.
Nov 29 18:14:46 srv1.loewenhaupt.com.br clamd[2639]: XMLDOCS support enabled.
Nov 29 18:14:46 srv1.loewenhaupt.com.br clamd[2639]: HWP3 support enabled.
Nov 29 18:14:46 srv1.loewenhaupt.com.br clamd[2639]: Self checking every 600 seconds.
Nov 29 18:24:46 srv1.loewenhaupt.com.br clamd[2639]: SelfCheck: Database status OK.
Nov 29 18:34:46 srv1.loewenhaupt.com.br clamd[2639]: SelfCheck: Database status OK.
Nov 29 18:44:46 srv1.loewenhaupt.com.br clamd[2639]: SelfCheck: Database status OK.
But the procmail.log give me this error msgs:
From securitycheck@emailsecuritycheck.net Tue Nov 29 18:37:48 2016
Subject: Test mail 2/7 (ID=xcWmslfdgxRiGJljrfuw==)
Folder: /home/loewe/Maildir/new/1480451871.4005_0.srv1.loewenhaupt.c 2136
Time:1480451871 From:securitycheck@emailsecuritycheck.net To:loewe@loewenhaupt.com.br User:loewe Size:2204 Dest:/home/loewe/Maildir/new/1480451871.4005_0.srv1.loewenhaupt.com.br Mode:None
ERROR: Could not lookup : Servname not supported for ai_socktype
procmail: Unable to treat as directory “/home/loewe/~/Maildir/.spam”
procmail: Error while writing to “/home/loewe/~/Maildir/.spam”
I have setup virtualmin to send all identified SPAM mail to the Spam folder… But as you can see, there is an error
Can anyoone helo me with this two erros msgs?
Regards
Mario
