I go on virtualmin system and setting validate virtual server validated now and tells me:
Beginning validation of selected virtual servers. Any problems found will be shown in red …
Nomesito.com
Webalizer reporting: No Apache logs found for virtual host nomesito.com
Log files rotation: No Apache logs found for virtual host nomesito.com
there won’t be any logs if it isn’t used yet.
if i go to nomesito.com I get to see this
[code:1]This is the placeholder for domain nomesito.com. If you see this page after uploading site content you probably have not replaced the index.html file.
This page has been automatically generated by Plesk.[/code:1]
My site is functional but maybe I have the wrong directory? I installed on the home site I created a directory user and inside the publi_html I installed the site that if I try to reach our see it
I tried to do bakup the virtual server and I say this:
Creating backup for virtual server nomesito.com …
Copying virtual server configuration ..
.. Done
Backing up Cron jobs ..
.. Ninth defined.
Creating TAR file directory of home ..
.. Done
Saving mail aliases ..
.. Done
Saving mail and FTP users ..
.. Done
Backing up mail and FTP user Cron jobs ..
.. None to backup
Copying Apache virtual host configuration ..
.. Done
Copying Webalizer configuration files ..
.. No logging directive found in Apache configuration!
Backup failed! See the progress output above for the reason why.
