I just installed Virtualmin and had my Cpanel run a full forced backup (which Virtualmin is replacing).
The Cpanel backup is not a tar.gz file, it was 2 directorys called dirs and files … within those directories are more tar files. So I tarred both the folders into one tar file and ftp’d the tar file off the server.
When trying to use migrate, loaded up the tar file but it keeps coming back with:
validation failed : Not a cPanel daily or home directory backup file
Any ideas?
