Hi
I just like to have a copy on the PC to look at, not always near an internet link so allows me to go through it in my own time.
Just viewed the log with putty.
I tried to send an email just before checking.
this is the last few lines in the log.
Apr 10 02:59:41 centos_pristine postfix/smtpd[6610]: fatal: parameter "smtpd_recipient_restrictions": specify at least one wor
king instance of: check_relay_domains, reject_unauth_destination, reject, defer or defer_if_permit
Apr 10 02:59:42 centos_pristine postfix/master[6368]: warning: process /usr/libexec/postfix/smtpd pid 6610 exit status 1
Apr 10 02:59:42 centos_pristine postfix/master[6368]: warning: /usr/libexec/postfix/smtpd: bad command startup – throttling
Apr 10 03:00:48 centos_pristine postfix/smtpd[6627]: fatal: parameter "smtpd_recipient_restrictions": specify at least one wor
Apr 10 03:00:49 centos_pristine postfix/master[6368]: warning: process /usr/libexec/postfix/smtpd pid 6627 exit status 1
Apr 10 03:00:49 centos_pristine postfix/master[6368]: warning: /usr/libexec/postfix/smtpd: bad command startup – throttling
Apr 10 03:01:49 centos_pristine postfix/smtpd[6653]: fatal: parameter "smtpd_recipient_restrictions": specify at least one wor
Apr 10 03:01:50 centos_pristine postfix/master[6368]: warning: process /usr/libexec/postfix/smtpd pid 6653 exit status 1
Apr 10 03:01:50 centos_pristine postfix/master[6368]: warning: /usr/libexec/postfix/smtpd: bad command startup – throttling
Apr 10 03:02:50 centos_pristine postfix/smtpd[7198]: fatal: parameter "smtpd_recipient_restrictions": specify at least one wor
Its seems to be a reap of the same few things.
Any suggestions
