I’m developing Virtualmin (GPL) billing system,Encountered a problem,
in Command Line Help
Deletes an existing Virtualmin virtual server and all sub-servers,
mailboxes and alias domains.
virtualmin delete-domain [–domain domain.name]*
[–user username]*
[–only]
This means that the remote API to delete a virtual server, must be added to domin and username parameters
The problem here, If my Customers Changed the domin Platform through Virtualmin Not in the billing system,now how can i know the new domain.
Yeah, the billing system may not be able to store the domain name… instead, if you only keep track of the username, you can then query Virtualmin using the API in order to determine what domains belong to that user whenever displaying the domains for that user.
Then, if the domain changes, no problem – next time the page is refreshed, it’ll be showing the correct domains.
