HELP I fail to see the site HELP
Good morning to everyone is a new user and are beginners with webmin,
I installed on the server webmin and I login I am watching the video for helping http://www.virtualmin.com/video-introduction.html but not me get to the server so I was wondering if you could help me understand how to access the server configuration thanks
( Excuse my English as are Italian and write in English with google translate )
For the log should I do with the server name and not root because I am not enter as root and then put the name of the server, but I did not do the same page in the guide is that I do not know where that is going to set the root server
This is the page that opens after I log:
http://img169.imageshack.us/img169/5816/loginqw6.jpg
Post edited by: zonekjdx, at: 2008/02/13 02:11
Post edited by: zonekjdx, at: 2008/02/13 02:12
Post edited by: zonekjdx, at: 2008/02/13 02:24<br><br>Post edited by: zonekjdx, at: 2008/02/13 05:09
Just change to the Virtualmin theme. You’re looking at the normal Webmin theme.
Browse to Webmin:Webmin Configuration:Webmin Themes, and set it to Virtualmin Framed Theme. (If you didn’t use install.sh to install Virtualmin, you’ll need to install the theme…you can download it at Webmin.com.)
Ok, I downloaded and installed the theme that I have recommended now I will give some hints for setting the first thing I do?
That is, the steps to create a piece for a user and a website to install more than one website. So you ask a lot but I need to be addressed in order to understand how to move into the panel
I installed the theme that I have said but has remained as it was the first even though I selected the new theme has not changed
Why since I installed the package theme Theme Virtualmin not change me more if I select the topics any of the issues that I have always leaves me the same theme
http://img210.imageshack.us/img210/4265/immaginepw9.jpg?s=1
Please give me a hand to understand what I have to do to start using the webmin
