Help - Has anyone successfully installed Koha
OS type and version Ubuntu 22.04.2
Virtualmin version 7.9.0
Hello, has anyone installed Koha (integrated library system) correctly?
Any guide?
First of all, Thanks
I’d recommend you try following the documentation provided by the Koha folks for installing on your OS, and then coming to us with problems that seem related to Virtualmin.
Virtualmin is not different. You have Apache or nginx, and they are configured in a very normal way in a Virtualmin system. If you can configure the software with Apache (or nginx), you can almost certainly do the exact same thing, regardless of Virtualmin being on the system.
