What is the difference between Virtualmin and Webmin? I really don't understand the distinction between the two pieces of software...
Webmin is the service that runs on port 10000, and is largely a tool providing sysadmins a GUI to manage their servers.
Virtualmin is a Webmin module, that adds the functionality to handle web/email/DNS hosting.
If you need to create an account for a client/customer, you would use a "Virtual Server" for that, correct?
Yup! That’s just a fancy name for a “domain”. Virtualmin started using that terminology before “Virtual Server” started being used to describe Virtual Machines… but now it’s just confusing
Virtual Servers do what exactly? Create a separate directory for customer's stuff?
Yeah, it’s what other control panels call a “domain”. When you create a Virtual Server in Virtualmin, that sets up a new user, along with the ability to host a website, DNS, email, and such.
I created a virtual server with everything default, then used the Wordpress installer to install Wordpress on that virtual server, but I get a 403 error. Is there something else I have to do? Or is the Wordpress installer supposed to take care of everything?
A 403 error typically means that the directory that was requested doesn’t have an index file in it, such as an index.html or index.php.
You’d want to ensure that the public_html folder has an index file.
When installing WordPress using the Install Script, by default it’s put into a sub-directory, not in the root public_html folder. If that’s where it was installed, you’d need to ensure that you’re accessing the sub-directory where WordPress was installed
