Hi, I recently tried two wordpress plugins to to convert wp to static (httpx://wordpress.org/plugins/jekyll-exporter/ and httpx://github.com/SchumacherFM/wordpress-to-hugo-exporter). I believe given the size of my site (1000’s of posts spanning over a very long time) both plugins failed and got 500 server error.
I simply deleted the plugins with Wordpress when they failed. I went to the dashboard and my local diskspace went from 49% used to whopping 68% used. I just can’t seem to locate where this bloat might have come from, I’ve checked all the wp* folders with today’s date, the root web folder with today’s date, and can’t seem to find it to clear. Not sure where else to look?
What are next steps I should do in VirtualMin?
- is there a utility or log I can check to find recent folder size increases (and an example would be great).
- Is there another place I should look? I am wrong assuming that the bloat it would only be home/website.com/ directory?
- Any obvious things I should check besides the above?
Thanks so much.
SYSTEM INFORMATION | |
