[HELP]Cloudmin GPL Xen + OVH IP Failover
Hey all, I need some help. I have set up Webmin, Virtualmin and Cloudmin on a newly installed CentOS 5.5 64-bit server from OVH (Kimsufi i7-2T), and I’m having problems trying to use my three failover IP’s for the Xen VM’s.
Basically, OVH tell you to use the following settings in your VM’s if your using the failover IP’s: http://help.ovh.co.uk/BridgeClient
But I’ve tried that, and my xen guests are inaccessiable via ping or any other methods, I’m just wondering if anyone else has experienced this issue, or has found a way around it?
Any help would be greatly appreciated
Hitting the same wall currently. The only difference between my and your setups is that I’ve installed only Webmin and Cloudmin GPL KVM without Virtualmin. Unfortunately, smilar instructions on http://guides.ovh.com/BridgeClient#link4 simply do not work. Have you been able to overcome this problem? If yes, then I’d appreciate if you could share how exactly you did?
