Having problems - updates Failed
OS type and version AlmaLinux 9.4
Usermin version 2.102
Virtualmin version 7.20.2
Theme version 21.20.7
Apache version 2.4.57
Package updates 12 package updates are available
I’m a newbie and was trying to get some websites that I migrated which were with older php versions a few days ago and may have done something to mess things up???
Now I have 12 updates and they failed this is what I got as below:
Building complete list of packages ..
Now updating kernel kernel-core kernel-devel kernel-headers kernel-modules kernel-modules-core kernel-tools kernel-tools-libs php-pecl-zip php74-php-pecl-zip php82-php-pecl-zip php83-php-pecl-zip ..
    Installing package(s) with command /bin/dnf -y update kernel.x86_64 kernel-core.x86_64 kernel-devel.x86_64 kernel-headers.x86_64 kernel-modules.x86_64 kernel-modules-core.x86_64 kernel-tools.x86_64 kernel-tools-libs.x86_64 php-pecl-zip.x86_64 php74-php-pecl-zip.x86_64 php82-php-pecl-zip.x86_64 php83-php-pecl-zip.x86_64 ..
    Last metadata expiration check: 0:30:56 ago on Fri Sep 27 22:07:03 2024.
    Error:
     Problem: package php-pecl-zip-1.22.4-1.el9.remi.7.4.x86_64 from remi-modular requires php(api) = 20190902-64, but none of the providers can be installed
      - package php-pecl-zip-1.22.4-1.el9.remi.7.4.x86_64 from remi-modular requires php(zend-abi) = 20190902-64, but none of the providers can be installed
      - cannot install both php-common-7.4.33-17.el9.remi.x86_64 from remi-modular and php-common-8.3.12-1.el9.remi.x86_64 from @System
      - cannot install both php-common-7.4.33-18.el9.remi.x86_64 from remi-modular and php-common-8.3.12-1.el9.remi.x86_64 from @System
      - cannot install the best update candidate for package php-pecl-zip-1.22.3-1.el9.remi.8.3.x86_64
      - problem with installed package php-common-8.3.12-1.el9.remi.x86_64
    (try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
    .. install failed!
No packages were installed. Check the messages above for the cause of the error.
I need all three PHP Versions as I am running
PHP-FPM 8.3.12 Server||
PHP-FPM 7.4.33 Server
PHP-FPM 8.2.24 Server
as websites have different versions Grrrrrrrrrrrr…
It was all working quite well before and I do have a snapshot when all was working very well and all was updating OK at Contabo (If that helps)
Please Help
ASM
using command line and try what is suggested.
  • you can try installing each package one by one.
  • Is this an issue with messed up repos?
Thanks stefan1959
I installed one at a time and all expet the php update for 8.3 all worked fine
Then I reinstalled version 8.3 and php-fm and rebooted, then did the last install it all went ok
rebooted again (just in case) now looks like all is working fine and all updates are done
Thanks again
Regards
ASM
