Having problems running a cron job.
Hi there,
I have a problem trying to get my cron job working.
The script runs fine when I run it from my browser,
it does everything it shoul, no errors.
I have set it up as a cron job and I am running it with the Run Now button
but I get a file error:
Output from command php -q /home/focus7/public_html/auto_support.php …
PHP Warning: require_once(/lib/swift_required.php): failed to open stream: No such file or directory in /home/focus7/public_html/auto_support.php on line 9
PHP Fatal error: require_once(): Failed opening required ‘/lib/swift_required.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) in /home/focus7/public_html/auto_support.php on line 9
<- Return to cron job | Return to cron list
The actual line it is failing on is the second one of these two:
$swift_path = $_SERVER[‘DOCUMENT_ROOT’]."/lib/swift_required.php";
require_once("$swift_path");
I use the path because in other scripts I call the library from different directories.
So, I assume that the cron job does not like the $_SERVER[‘DOCUMENT_ROOT’]. bit ?
How should I address the swift script to make cron happy ?
Can I do it in a way that will work from the browser as well ?
( I can hard code the path, it doesn’t need to have the “doc_root” bit in it for this
particular script.)
Thanks for some guidance.
Well, “$_SERVER[‘DOCUMENT_ROOT’]” is a variable that’s set by Apache.
So if you’re running it from Cron, rather than serving it from a website, that variable will be empty.
To fix that, you’d just have to explicitly set the path rather than relying on that variable.
Thanks for the help,
it is working nicely now :slight_smile:
