Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
Transaction Summary
Install 124 Package(s)
Upgrade 29 Package(s)
Total size: 135 M
Downloading Packages:
Running rpm_check_debug
ERROR with rpm_check_debug vs depsolve:
e2fsprogs is needed by quota-1:3.17-20.el6.x86_64
libext2fs.so.2()(64bit) is needed by quota-1:3.17-20.el6.x86_64
** Found 2 pre-existing rpmdb problem(s), ‘yum check’ output follows:
1:quota-3.17-16.el6.x86_64 has missing requires of e2fsprogs
1:quota-3.17-16.el6.x86_64 has missing requires of libext2fs.so.2()(64bit)
Your transaction was saved, rerun it with: yum load-transaction /tmp/yum_save_tx-2014-02-01-04-556jXws4.yumtx
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
any one help please
