On a new server with CSF installed and 21 port opened I can’t connect to the server. It tries but is not listing the directory files. Once I turn off the CSF it works fine.
Under messages this is the relevant (I guess ?) part (I swapped IPs etc):
If its timing out on login, port 21 is not open for incoming. If its logging in fine but timing out listing directory, port 20 is not open. I believe 20 needs to be open for outgoing only, but try in and out then narrow it down. If 20 can not be opened, will have to open passive port range to match passive port range used by your ftp client.
20 and 21 ports are opened. I’m running latest versions on everything installed.
This is very bizarre, why on earth it doesn’t work out of the box when you open those ports…
I had to setup passive ports range in proftpd.conf and then to open all those ports on csf to make it work.
If you are using passive mode, then you need to set that up additionally. I think its not enabled by default.
Thats why it properly didnt work out of the box.
