FTP Users Please Help
I have 4 sites on a rackspace servers.
I need to add an FTP user to each of my sites.
Each with their own creds.
Each only permitted to access, edit and upload files to
their given sites.
I have added FTP user (in the upper right)
I test the user. I can log in on my mac using fetch.
But none of the actual users can login using filezilla.
When they login they get a blank directory.
When I login I see it all.
So what needs to happen, how do I get this to work for the others?
Appreciate you time!
It may be an active vs passive FTP issue. Try taking a look at the article here titled “FTP Service isn’t working”, and see if that helps:
https://www.virtualmin.com/documentation/web/faq
The final step worked. Perfectly. Thank you so much!
