Ftp for virtual servers?
I’ve just created a new virtual server, but I can’t seem to connect with FTP… Do I need to do something first?
I have installed vsftpd on my Centos 5.2 server, and also the module for configuring this in webmin…
This is the response I get:
"Unexpected response: OOPS: cannot change directory:/home/testing
500: OOPS: cannot change directory:/home/testing"
Is there anything I need to do? I find this to be pretty confusing… When I go to edit mail and ftp users, it shows "IMAP/ftp login testing", "Login access: email, ssh, ftp"
But then there is a separate link for adding a "website ftp access user", when I click on that, the title says "create mailbox in domain" ?
Thanks in advance,
Wesley<br><br>Post edited by: wesleyh, at: 2008/12/04 11:18
Hi Wesley, a few questions for you –
  1. Does the home directory exist? Try: ls -l /home/testing
  2. Is SELinux enabled? It could be interfering – run “sestatus” to find out if it’s running.
  3. Does anything show up in /var/log/messages, /var/log/secure, or vsftp’s logfile that provides more insight into the issue?
This is now fixed, it was indeed selinux.
thanks :slight_smile:
