FTP connection problem
I have successfully set up a virtual server and can access the start page.
When trying to ftp into the site using WS_FTP, I receive the following and cannot log in. Is there a setting I’ve missed? Please help!
connecting to 62.149.36.18:21
Connected to 62.149.36.18 port 21
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 1 of 50 allowed.
220-Local time is now 06:16. Server port: 21.
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER gallifreymatrix
331 User gallifreymatrix OK. Password required
PASS (hidden)
530 Login authentication failed
! Logon failure, so quitting
Well, the error is there: 530 Login authentication failed
Are you using the correct credentials? You can query them via Edit Virtual Server -> Configurable settings -> Administration password: Show.
