SYSTEM INFORMATION | |
OS type and version | UBUNTU 20.04 |
Webmin version | 2.101 |
Virtualmin version | 7.7 |
Related packages | SUGGESTED |
Is there any way to see whats taking up so much storage space under “root”?
Thank you!
Thank you!
du -h ~root
will give you directories
find
to give you files (but it will be a long list!)
maybe the OP wants to know what total files are owned by root so
find / -user root > root_files.txt
This creates a text file you can read through it or cat & grep it, but I guess the OP just wants the contents of the root’s ‘home’ directory (/root) TBF my root directory is really big (by design) and I get loads of entries from the find command
Thanks jimr1 for correcting my vague spur of the moment suggestion. I would use du
first to find the biggest directory then find
to see if anything more specific
