File Manager - when will it work without Java???
Hi All
OSX / FF / Chrome / … etc. They all banned Java in their new releases and everytime you want to use Virtualmin or webmin you need to install unsafe software on your machines like Java and on many browsers it is even not at all working. When will Virtualmin and Webmin use HTML5 or other NON Java Filemanager - like i.e. AJENTI does it perfectly and many other Web Panels since years?
Andi
We are indeed planning to replace the Java filemanager.
Something that perhaps you could perhaps try in the meantime is this one here:
https://www.virtualmin.com/node/36839
