Hi all.
I have FC5 installed for sometime know and i was server my website from a setup at www.stanton-finley.net. Well i set up mysql, apache and the whole works to start serving my website with dyndns. Know i’m trying out Virtualmin GPL but i can’t seem to get my domian i created in Virtualmin to work, can someone please help… Do i have to remove the settings i had from the previous settings I had and let Virtualmin do everything and how to do i go about it… I’ll appreciate your help …
i can’t seem to get my domian i created in Virtualmin to work, can someone please help.
You’re going to have to be much more specific.
What isn’t working about the domain?
Not usually. Just depends on what settings you’re talking about. Virtualmin works with a very wide variety of configurations, but you might have to configure it to know how to deal with your settings.
Again, we need more information to be able to help you.
Stuff like:
Have you tested to be sure DNS is being served correctly? e.g. when you run "host domainname.tld" you get the right IP back.
Have you looked in the access_log and error_log for the domain in question to see if there are any clues to what’s happening? Virtualmin puts these in /home/domainname/logs by default.
Are you sure all necessary services are running?
service named status
service httpd status
Assuming you’re serving names locally, and installed all software from RPM.
