HI
My “Administrator User” and “Home Directory” under the Feature and Plugins is not working. It has a cross in the checkbox. Does it needs to be fixed? If so, how?
Yamin
HI
Yamin
Please elaborate “is not working”. A checkbox where? To the left, or under “Default”?
To the left it has a cross on it, for the rest it has a tick on it
The cross is, even if it looks confusing, correct. It means the feature is turned on. And actually you can’t even turn it off. From the help page:
For each you can control its availability using the checkbox in the first column, except for the Home directory and Administration user which are so critical that they cannot be turned off.
Hi
Ok thanks, I am a newbie.
I am gone purchase this product and try to get to grips with this,.
Regards
Yamin
You’re welcome. And yeah, its feature richness can be intimidating. But you’ll get good help here.
