Hi, well it depends what you want to run…(for example some cms-es require some php ‘extentions’ or modules…) in a case you are using debian you can write them in one line command like: apt-get install php5-curl php5-dev php5-gd ..all others you need and just press enter and install them really. You dont have to install all of them, just the one you need/want.
Here is list of all of them with description what they are for:
php5-cgi - server-side, HTML-embedded scripting language (CGI binary)
php5-cli - command-line interpreter for the php5 scripting language
php5-common - Common files for packages built from the php5 source
php5-curl - CURL module for php5
php5-dbg - Debug symbols for PHP5
php5-dev - Files for PHP5 module development
php5-gd - GD module for php5
php5-gmp - GMP module for php5
php5-json - JSON module for php5
php5-ldap - LDAP module for php5
php5-mysql - MySQL module for php5
php5-odbc - ODBC module for php5
php5-pgsql - PostgreSQL module for php5
php5-pspell - pspell module for php5
php5-readline - Readline module for php5
php5-recode - recode module for php5
php5-snmp - SNMP module for php5
php5-sqlite - SQLite module for php5
php5-tidy - tidy module for php5
php5-xmlrpc - XML-RPC module for php5
php5-xsl - XSL module for php5
php5-adodb - Extension optimising the ADOdb database abstraction library
php5-apcu - APC User Cache for PHP 5
php5-enchant - Enchant module for php5
php5-exactimage - fast image manipulation library (PHP bindings)
php5-fpm - server-side, HTML-embedded scripting language (FPM-CGI binary)
php5-gdcm - Grassroots DICOM PHP5 bindings
php5-gearman - PHP wrapper to libgearman
php5-geoip - GeoIP module for php5
php5-gnupg - wrapper around the gpgme library
php5-imagick - ImageMagick module for php5
php5-imap - IMAP module for php5
php5-interbase - interbase/firebird module for php5
php5-intl - internationalisation module for php5
php5-lasso - Library for Liberty Alliance and SAML protocols - PHP 5 bindings
php5-librdf - PHP5 language bindings for the Redland RDF library
php5-mapscript - * php5-cgi module for MapServer
php5-mcrypt - MCrypt module for php5
php5-memcache - memcache extension module for PHP5
php5-memcached - memcached extension module for PHP5, uses libmemcached
php5-midgard2 - Midgard2 Content Repository - PHP5 language bindings and module
php5-ming - Ming module for php5
php5-mongo - MongoDB database driver
php5-msgpack - PHP extension for interfacing with MessagePack
php5-mysqlnd - MySQL module for php5 (Native Driver)
php5-mysqlnd-ms - MySQL replication and load balancing module for PHP
php5-oauth - OAuth 1.0 consumer and provider extension
php5-pinba - Pinba module for PHP 5
php5-ps - ps module for PHP 5
php5-radius - PECL radius module for PHP 5
php5-redis - PHP extension for interfacing with Redis
php5-remctl - PECL module for Kerberos-authenticated command execution
php5-rrd - PHP bindings to rrd tool system
php5-sasl - Cyrus SASL Extension
php5-stomp - Streaming Text Oriented Messaging Protocol (STOMP) client module for PHP 5
php5-svn - PHP Bindings for the Subversion Revision control system
php5-sybase - Sybase / MS SQL Server module for php5
php5-tokyo-tyrant - PHP interface to Tokyo Cabinet's network interface, Tokyo Tyrant
Hello, steping here Just to give you guys a feedback on my problem.
I figured out why it was happening, apparently you cannot enable mod_userdir apache module when FCGI is enabled, (yes I did not know that and i’m a noob) that what was causing the code not being interpreted, but when I try the “WEBSITE PREVIEW” everything works fine.
So now I just need to find a way to “Preview a website” without the user being authenticated using a single URL,
Does anyone have an idea how this can be implemented? I read somewhere that it could be done by configuring proxying a website (using the option Edit Proxy Website), how is that possible ?
