cat /etc/redhat-release
Red Hat Enterprise Linux Server release 6.1 (Santiago)
./install.sh
Welcome to the Virtualmin GPL installer, version 1.0.6
WARNING:
The installation is quite stable and functional when run on a freshly
installed supported Operating System, but upgrades from existing .wbm-
based systems, or systems that already have Apache VirtualHost
directives or mail users, will very likely run
into numerous problems.
Please read the Virtualmin Administrators Guide before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system! It should only be
used to install Virtualmin, on a supported OS. If you have previously
installed Virtualmin via this script or the GPL version of this script,
upgrades and updates should be handled within Virtualmin itself. Once
Virtualmin is installed, you never need to run this script again.
The systems currently supported by install.sh are:
CentOS 4 and 5 on i386 and x86_64
Debian 4.0, 5.0 and 6.0 on i386 and amd64
Ubuntu 8.04 LTS and 10.04 LTS on i386 and amd64
If your OS is not listed above, this script will fail. More details
about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) y
Checking for HTTP client…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as server4.islam.ws
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: Red Hat Enterprise Linux
INFO - Operating system version: 6
INFO - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - Disabling SELinux during installation…
/usr/sbin/setenforce: SELinux is disabled
INFO - setenforce 0 failed: 1
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-beta: key 1 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-beta: key 2 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-legacy-former: key 1 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-legacy-release: key 1 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-legacy-rhx: key 1 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-release: key 1 import failed.
error: /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-release: key 2 import failed.
INFO - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
Running updatedb so locate works…this will take a little while.
Attempting to import various system RPM-GPG-KEY files…Errors may occur,
if you’ve already imported them. It is safe to ignore these errors.
INFO - Succeeded.
INFO - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
…in progress, please wait…
-http://software.virtualmin.com/gpl/rhel/6Server/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - “The requested URL returned error: 404”
Trying other mirror.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: virtualmin. Please verify its path and try again
/usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
INFO - 2011-08-18 07:32:15 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2011-08-18 07:32:15 - Loading OS selection library…
INFO - 2011-08-18 07:32:15 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2011-08-18 07:32:15 - Loading OS list…
INFO - 2011-08-18 07:32:15 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2011-08-18 07:32:16 - Operating system name: Red Hat Enterprise Linux
INFO - 2011-08-18 07:32:16 - Operating system version: 6
INFO - 2011-08-18 07:32:16 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2011-08-18 07:32:16 - Disabling SELinux during installation…
INFO - 2011-08-18 07:32:16 - setenforce 0 failed: 1
INFO - 2011-08-18 07:32:16 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2011-08-18 07:32:16 - Succeeded.
INFO - 2011-08-18 07:32:16 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
Loaded plugins: product-id, rhnplugin, subscription-manager
Updating Red Hat repositories.
FATAL -
Fatal Error Occurred: Something went wrong during installation: 0
