Have installed Ubuntu 12.10 server fresh and am trying to setup virtualmin. LAMP is setup properly and I can access the default web pages from a remote machine on my network.
I’ve attempted several times to no avail. The previous attempt complained about not being able to find the the package webmin, usermin and scponly. I installed webmin and usermin successfully and tried running the script… Not sure what if anything I’m doing wrong. I’ve run this as root, also as sudo.
Is 12.10 not an option?
IWelcome to the Virtualmin GPL installer, version 1.0.9
WARNING:
The installation is quite stable and functional when run on a freshly
installed supported Operating System.
If you have existing websites, email users, or if you manually installed
Virtualmin via a Webmin ‘wbm’ module, you are likely to run into problems.
Please read the Virtualmin Administrators Guide before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system! It should only be
used to perform your initial Virtualmin installation. If you have previously
run the Virtualmin installer, you can perform upgrades and updates from within
Virtualmin itself, or using your system’s package manager. Once Virtualmin is
installed, you never need to run this script again.
The systems currently supported by install.sh are:
CentOS and RHEL 5-6 on i386 and x86_64
Scientific Linux 6 on i386 and x86_64
Debian 6.0 on i386 and amd64
Ubuntu 8.04 LTS and 10.04 LTS, and 12.04 LTS on i386 and amd64
Amazon Linux 2012.03 on i386 and x86_64
FreeBSD 7.0 and 8 on i386 and amd64
If your OS is not listed above, this script will fail. More details
about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) y
Checking for HTTP client…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as t2-vps.schiff.is-a-geek.com
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: Ubuntu Linux
INFO - Operating system version: 12.10
INFO - Configuring package manager for Ubuntu Linux 12.10…
INFO - Enabling universe repositories, if not already available…
INFO - Disabling cdrom repositories…
Hit http://webmin.mirror.somersettechsolutions.co.uk sarge Release.gpg
Hit http://us.archive.ubuntu.com quantal Release.gpg
Hit http://us.archive.ubuntu.com quantal-updates Release.gpg
Hit http://download.virtualbox.org quantal Release.gpg
Hit http://download.webmin.com sarge Release.gpg
Hit http://us.archive.ubuntu.com quantal-backports Release.gpg
Hit http://security.ubuntu.com quantal-security Release.gpg
Hit http://us.archive.ubuntu.com quantal/main Sources
Hit http://download.virtualbox.org quantal/contrib amd64 Packages
Hit http://us.archive.ubuntu.com quantal/restricted Sources
Hit http://webmin.mirror.somersettechsolutions.co.uk sarge/contrib amd64 Packages
Hit http://us.archive.ubuntu.com quantal/universe Sources
Hit http://us.archive.ubuntu.com quantal/multiverse Sources
Hit http://us.archive.ubuntu.com quantal/main amd64 Packages
Hit http://download.virtualbox.org quantal/contrib i386 Packages
Hit http://security.ubuntu.com quantal-security/main Sources
Hit http://webmin.mirror.somersettechsolutions.co.uk sarge/contrib i386 Packages
Hit http://us.archive.ubuntu.com quantal/restricted amd64 Packages
Hit http://us.archive.ubuntu.com quantal/universe amd64 Packages
Hit http://us.archive.ubuntu.com quantal/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com quantal/main i386 Packages
Hit http://download.webmin.com sarge/contrib amd64 Packages
Hit http://us.archive.ubuntu.com quantal/restricted i386 Packages
Hit http://us.archive.ubuntu.com quantal/universe i386 Packages
Hit http://security.ubuntu.com quantal-security/restricted Sources
Hit http://us.archive.ubuntu.com quantal/multiverse i386 Packages
Hit http://download.webmin.com sarge/contrib i386 Packages
Hit http://us.archive.ubuntu.com quantal/main Translation-en
Hit http://security.ubuntu.com quantal-security/universe Sources
Hit http://us.archive.ubuntu.com quantal/multiverse Translation-en
Hit http://us.archive.ubuntu.com quantal/restricted Translation-en
Hit http://security.ubuntu.com quantal-security/multiverse Sources
Hit http://us.archive.ubuntu.com quantal/universe Translation-en
Hit http://us.archive.ubuntu.com quantal-updates/main Sources
Hit http://us.archive.ubuntu.com quantal-updates/restricted Sources
Hit http://security.ubuntu.com quantal-security/main amd64 Packages
Hit http://us.archive.ubuntu.com quantal-updates/universe Sources
Hit http://us.archive.ubuntu.com quantal-updates/multiverse Sources
Hit http://us.archive.ubuntu.com quantal-updates/main amd64 Packages
Hit http://us.archive.ubuntu.com quantal-updates/restricted amd64 Packages
Ign http://download.virtualbox.org quantal/contrib Translation-en_US
Hit http://us.archive.ubuntu.com quantal-updates/universe amd64 Packages
Hit http://security.ubuntu.com quantal-security/restricted amd64 Packages
Hit http://us.archive.ubuntu.com quantal-updates/multiverse amd64 Packages
Hit http://security.ubuntu.com quantal-security/universe amd64 Packages
Hit http://us.archive.ubuntu.com quantal-updates/main i386 Packages
Hit http://us.archive.ubuntu.com quantal-updates/restricted i386 Packages
Hit http://us.archive.ubuntu.com quantal-updates/universe i386 Packages
Hit http://us.archive.ubuntu.com quantal-updates/multiverse i386 Packages
Hit http://security.ubuntu.com quantal-security/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com quantal-updates/main Translation-en
Hit http://us.archive.ubuntu.com quantal-updates/multiverse Translation-en
Hit http://security.ubuntu.com quantal-security/main i386 Packages
Ign http://webmin.mirror.somersettechsolutions.co.uk sarge/contrib Translation-en_US
Hit http://us.archive.ubuntu.com quantal-updates/restricted Translation-en
Hit http://us.archive.ubuntu.com quantal-updates/universe Translation-en
Hit http://us.archive.ubuntu.com quantal-backports/main Sources
Hit http://security.ubuntu.com quantal-security/restricted i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/restricted Sources
Hit http://us.archive.ubuntu.com quantal-backports/universe Sources
Hit http://security.ubuntu.com quantal-security/universe i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/multiverse Sources
Hit http://us.archive.ubuntu.com quantal-backports/main amd64 Packages
Hit http://us.archive.ubuntu.com quantal-backports/restricted amd64 Packages
Hit http://security.ubuntu.com quantal-security/multiverse i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/universe amd64 Packages
Hit http://us.archive.ubuntu.com quantal-backports/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com quantal-backports/main i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/restricted i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/universe i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/multiverse i386 Packages
Hit http://us.archive.ubuntu.com quantal-backports/main Translation-en
Hit http://security.ubuntu.com quantal-security/main Translation-en
Hit http://us.archive.ubuntu.com quantal-backports/multiverse Translation-en
Hit http://us.archive.ubuntu.com quantal-backports/restricted Translation-en
Hit http://us.archive.ubuntu.com quantal-backports/universe Translation-en
Hit http://security.ubuntu.com quantal-security/multiverse Translation-en
Hit http://security.ubuntu.com quantal-security/restricted Translation-en
Hit http://security.ubuntu.com quantal-security/universe Translation-en
Ign http://us.archive.ubuntu.com quantal/main Translation-en_US
Ign http://us.archive.ubuntu.com quantal/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com quantal/restricted Translation-en_US
Ign http://us.archive.ubuntu.com quantal/universe Translation-en_US
Ign http://us.archive.ubuntu.com quantal-updates/main Translation-en_US
Ign http://us.archive.ubuntu.com quantal-updates/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com quantal-updates/restricted Translation-en_US
Ign http://us.archive.ubuntu.com quantal-updates/universe Translation-en_US
Ign http://us.archive.ubuntu.com quantal-backports/main Translation-en_US
Ign http://us.archive.ubuntu.com quantal-backports/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com quantal-backports/restricted Translation-en_US
Ign http://us.archive.ubuntu.com quantal-backports/universe Translation-en_US
Ign http://security.ubuntu.com quantal-security/main Translation-en_US
Ign http://security.ubuntu.com quantal-security/multiverse Translation-en_US
Ign http://security.ubuntu.com quantal-security/restricted Translation-en_US
Ign http://security.ubuntu.com quantal-security/universe Translation-en_US
Ign http://download.webmin.com sarge/contrib Translation-en_US
Reading package lists… Done
INFO - Cleaning up apt headers and packages, so we can start fresh…
INFO -
INFO - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - Installing Webmin and Virtualmin package signing keys…
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - OK
INFO - OK
INFO - Hit
INFO - Removing Debian standard Webmin package, if they exist…
INFO - Removing Debian apache packages…
INFO - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql
…in progress, please wait…
.E: Unable to locate package scponly
/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
INFO - 2013-04-14 21:41:25 -
INFO - 2013-04-14 21:41:25 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2013-04-14 21:41:25 - Installing Webmin and Virtualmin package signing keys…
INFO - 2013-04-14 21:41:25 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2013-04-14 21:41:25 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2013-04-14 21:41:25 - OK
INFO - 2013-04-14 21:41:37 - Hit
INFO - 2013-04-14 21:41:37 - Removing Debian standard Webmin package, if they exist…
INFO - 2013-04-14 21:41:37 - Removing Debian apache packages…
DEBUG - 2013-04-14 21:41:38 - Reading
INFO - 2013-04-14 21:41:38 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql
Building dependency tree…
Reading state information…
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
