I can’t install Virtualmin, tried to look for an answer but nothing solve the issue…
Here is the log, maybe someone can help?
INFO - 2017-04-25 17:21:47 - Started installation log in /root/virtualmin-install.log
DEBUG - 2017-04-25 17:21:47 - Install mode: full
DEBUG - 2017-04-25 17:21:47 - Product: Virtualmin GPL
DEBUG - 2017-04-25 17:21:47 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2017-04-25 17:21:47 - install.sh version: 1.1.5
INFO - 2017-04-25 17:21:47 - Checking for fully qualified hostname…
INFO - 2017-04-25 17:21:47 - Hostname OK: fully qualified as vultr.guest
INFO - 2017-04-25 17:21:47 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2017-04-25 17:21:47 - Loading OS selection library…
INFO - 2017-04-25 17:21:47 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2017-04-25 17:21:47 - Loading OS list…
INFO - 2017-04-25 17:21:47 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2017-04-25 17:21:47 - Operating system name: CentOS Linux
INFO - 2017-04-25 17:21:47 - Operating system version: 6
INFO - 2017-04-25 17:21:47 - Configuring package manager for CentOS Linux 6…
INFO - 2017-04-25 17:21:47 - Disabling SELinux during installation…
INFO - 2017-04-25 17:21:47 - setenforce 0 failed: 1
INFO - 2017-04-25 17:21:48 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2017-04-25 17:21:48 - Succeeded.
INFO - 2017-04-25 17:21:48 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Loaded plugins: fastestmirror, replace
Setting up Install Process
Loading mirror speeds from cached hostfile
- base: mirror.umd.edu
- epel: fedora-epel.mirrors.tds.net
- extras: chicago.gaminghost.co
- ius: ius.mirror.constant.com
- updates: mirror.cc.columbia.edu
Package 2:postfix-2.6.6-8.el6.x86_64 already installed and latest version
Package 1:quota-3.17-23.el6.x86_64 already installed and latest version
Package iptables-1.4.7-16.el6.x86_64 already installed and latest version
Package openssl-1.0.1e-57.el6.x86_64 already installed and latest version
Package python-2.6.6-66.el6_8.x86_64 already installed and latest version
No package mariadb available.
No package mariadb-server available.
No package rh-postgresql available.
No package rh-postgresql-server available.
Package logrotate-3.7.8-28.el6.x86_64 already installed and latest version
Package cyrus-sasl-2.1.23-15.el6_6.2.x86_64 already installed and latest version
No package perl-LWP-Protocol-https available.
Resolving Dependencies
–> Running transaction check
—> Package bind.x86_64 32:9.8.2-0.62.rc1.el6_9.1 will be installed
–> Processing Dependency: bind-libs = 32:9.8.2-0.62.rc1.el6_9.1 for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: portreserve for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: liblwres.so.80()(64bit) for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: libisccfg.so.82()(64bit) for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: libisccc.so.80()(64bit) for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: libisc.so.83()(64bit) for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: libdns.so.81()(64bit) for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
–> Processing Dependency: libbind9.so.80()(64bit) for package: 32:bind-9.8.2-0.62.rc1.el6_9.1.x86_64
—> Package bind-utils.x86_64 32:9.8.2-0.62.rc1.el6_9.1 will be installed
—> Package cyrus-sasl-gssapi.x86_64 0:2.1.23-15.el6_6.2 will be installed
—> Package dovecot.x86_64 1:2.0.9-22.el6 will be installed
—> Package httpd.x86_64 1:2.2.15-54.el6.vm will be installed
–> Processing Dependency: httpd-tools = 1:2.2.15-54.el6.vm for package: 1:httpd-2.2.15-54.el6.vm.x86_64
–> Processing Dependency: apr-util-ldap for package: 1:httpd-2.2.15-54.el6.vm.x86_64
–> Processing Dependency: /etc/mime.types for package: 1:httpd-2.2.15-54.el6.vm.x86_64
—> Package mailman.x86_64 3:2.1.12-26.el6 will be installed
—> Package mlocate.x86_64 0:0.22.2-6.el6 will be installed
—> Package mod_dav_svn.x86_64 0:1.6.11-15.el6_7 will be installed
—> Package mod_perl.x86_64 0:2.0.4-11.el6_5 will be installed
–> Processing Dependency: perl(ExtUtils::MakeMaker) for package: mod_perl-2.0.4-11.el6_5.x86_64
–> Processing Dependency: perl(BSD::Resource) for package: mod_perl-2.0.4-11.el6_5.x86_64
—> Package mod_python.x86_64 0:3.3.1-16.el6 will be installed
—> Package mod_ssl.x86_64 2:2.2.15-54.el6.vm will be installed
—> Package mysql.x86_64 0:5.1.73-8.el6_8 will be installed
–> Processing Dependency: mysql-libs = 5.1.73-8.el6_8 for package: mysql-5.1.73-8.el6_8.x86_64
—> Package mysql-devel.x86_64 0:5.1.73-8.el6_8 will be installed
–> Processing Dependency: openssl-devel for package: mysql-devel-5.1.73-8.el6_8.x86_64
—> Package mysql-server.x86_64 0:5.1.73-8.el6_8 will be installed
–> Processing Dependency: perl-DBI for package: mysql-server-5.1.73-8.el6_8.x86_64
–> Processing Dependency: perl(DBI) for package: mysql-server-5.1.73-8.el6_8.x86_64
—> Package perl-Crypt-SSLeay.x86_64 0:0.57-17.el6 will be installed
—> Package perl-DBD-MySQL.x86_64 0:4.013-3.el6 will be installed
—> Package perl-DBD-Pg.x86_64 0:2.15.1-4.el6_3 will be installed
–> Processing Dependency: libpq.so.5()(64bit) for package: perl-DBD-Pg-2.15.1-4.el6_3.x86_64
—> Package perl-XML-Simple.noarch 0:2.18-6.el6 will be installed
–> Processing Dependency: perl(XML::Parser) for package: perl-XML-Simple-2.18-6.el6.noarch
—> Package php.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: php-common(x86-64) = 5.3.3-49.el6 for package: php-5.3.3-49.el6.x86_64
–> Processing Dependency: php-cli(x86-64) = 5.3.3-49.el6 for package: php-5.3.3-49.el6.x86_64
—> Package php-gd.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-imap.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: libc-client.so.2007()(64bit) for package: php-imap-5.3.3-49.el6.x86_64
—> Package php-mbstring.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-mysql.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-odbc.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: libodbc.so.2()(64bit) for package: php-odbc-5.3.3-49.el6.x86_64
—> Package php-pear.noarch 1:1.9.4-5.el6 will be installed
—> Package php-pgsql.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-snmp.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: net-snmp for package: php-snmp-5.3.3-49.el6.x86_64
–> Processing Dependency: libnetsnmp.so.20()(64bit) for package: php-snmp-5.3.3-49.el6.x86_64
—> Package php-xml.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-xmlrpc.x86_64 0:5.3.3-49.el6 will be installed
—> Package postgresql.x86_64 0:8.4.20-7.el6 will be installed
—> Package postgresql-server.x86_64 0:8.4.20-7.el6 will be installed
—> Package procmail.x86_64 0:3.22-25.1.el6_5.1 will be installed
—> Package ruby.x86_64 0:1.8.7.374-5.el6 will be installed
–> Processing Dependency: ruby-libs = 1.8.7.374-5.el6 for package: ruby-1.8.7.374-5.el6.x86_64
–> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby-1.8.7.374-5.el6.x86_64
—> Package ruby-devel.x86_64 0:1.8.7.374-5.el6 will be installed
—> Package rubygems.noarch 0:1.3.7-5.el6 will be installed
–> Processing Dependency: ruby-rdoc for package: rubygems-1.3.7-5.el6.noarch
—> Package spamassassin.x86_64 0:3.3.1-3.el6 will be installed
–> Processing Dependency: perl-HTML-Parser >= 3.43 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(NetAddr::IP) >= 4.000 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(IO::Zlib) >= 1.04 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(HTML::Parser) >= 3.43 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Archive::Tar) >= 1.23 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Time::HiRes) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Net::DNS) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Mail::DKIM) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(LWP::UserAgent) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(HTTP::Date) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Encode::Detect) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Archive::Tar) for package: spamassassin-3.3.1-3.el6.x86_64
—> Package subversion.x86_64 0:1.6.11-15.el6_7 will be installed
–> Processing Dependency: perl(URI) >= 1.17 for package: subversion-1.6.11-15.el6_7.x86_64
–> Processing Dependency: libneon.so.27()(64bit) for package: subversion-1.6.11-15.el6_7.x86_64
—> Package webalizer.x86_64 0:2.21_02-3.3.el6 will be installed
–> Processing Dependency: libgd.so.2()(64bit) for package: webalizer-2.21_02-3.3.el6.x86_64
—> Package apr-util-ldap.x86_64 0:1.3.9-3.el6_0.1 will be installed
—> Package bind-libs.x86_64 32:9.8.2-0.62.rc1.el6_9.1 will be installed
—> Package gd.x86_64 0:2.0.35-11.el6 will be installed
—> Package httpd-tools.x86_64 0:2.2.15-59.el6.centos will be updated
—> Package httpd-tools.x86_64 1:2.2.15-54.el6.vm will be an update
—> Package libc-client.x86_64 0:2007e-11.el6 will be installed
—> Package mailcap.noarch 0:2.1.31-2.el6 will be installed
—> Package mysql-libs.x86_64 0:5.1.73-8.el6_8 will be installed
—> Package neon.x86_64 0:0.29.3-3.el6_4 will be installed
–> Processing Dependency: libproxy.so.0()(64bit) for package: neon-0.29.3-3.el6_4.x86_64
–> Processing Dependency: libpakchois.so.0()(64bit) for package: neon-0.29.3-3.el6_4.x86_64
—> Package net-snmp.x86_64 1:5.5-60.el6 will be installed
–> Processing Dependency: libsensors.so.4()(64bit) for package: 1:net-snmp-5.5-60.el6.x86_64
—> Package net-snmp-libs.x86_64 1:5.5-60.el6 will be installed
—> Package openssl-devel.x86_64 0:1.0.1e-57.el6 will be installed
–> Processing Dependency: zlib-devel for package: openssl-devel-1.0.1e-57.el6.x86_64
–> Processing Dependency: krb5-devel for package: openssl-devel-1.0.1e-57.el6.x86_64
—> Package perl-Archive-Tar.x86_64 0:1.58-144.el6 will be installed
–> Processing Dependency: perl(Package::Constants) for package: perl-Archive-Tar-1.58-144.el6.x86_64
–> Processing Dependency: perl(Compress::Zlib) for package: perl-Archive-Tar-1.58-144.el6.x86_64
—> Package perl-BSD-Resource.x86_64 0:1.29.03-3.el6 will be installed
—> Package perl-DBI.x86_64 0:1.609-4.el6 will be installed
—> Package perl-Encode-Detect.x86_64 0:1.01-2.el6 will be installed
—> Package perl-ExtUtils-MakeMaker.x86_64 0:6.55-144.el6 will be installed
–> Processing Dependency: perl-devel for package: perl-ExtUtils-MakeMaker-6.55-144.el6.x86_64
–> Processing Dependency: perl(Test::Harness) for package: perl-ExtUtils-MakeMaker-6.55-144.el6.x86_64
—> Package perl-HTML-Parser.x86_64 0:3.64-2.el6 will be installed
–> Processing Dependency: perl(HTML::Tagset) >= 3.03 for package: perl-HTML-Parser-3.64-2.el6.x86_64
–> Processing Dependency: perl(HTML::Tagset) for package: perl-HTML-Parser-3.64-2.el6.x86_64
—> Package perl-IO-Socket-INET6.noarch 0:2.56-4.el6 will be installed
–> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6-2.56-4.el6.noarch
—> Package perl-IO-Socket-SSL.noarch 0:1.31-3.el6_8.2 will be installed
–> Processing Dependency: perl-Net-SSLeay >= 1.35-10.el6_8.1 for package: perl-IO-Socket-SSL-1.31-3.el6_8.2.noarch
–> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.31-3.el6_8.2.noarch
—> Package perl-IO-Zlib.x86_64 1:1.09-144.el6 will be installed
—> Package perl-Mail-DKIM.noarch 0:0.37-2.el6 will be installed
–> Processing Dependency: perl(Mail::Address) for package: perl-Mail-DKIM-0.37-2.el6.noarch
–> Processing Dependency: perl(Digest::SHA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
–> Processing Dependency: perl(Crypt::OpenSSL::RSA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
—> Package perl-Net-DNS.x86_64 0:0.65-5.el6 will be installed
–> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS-0.65-5.el6.x86_64
—> Package perl-NetAddr-IP.x86_64 0:4.027-7.el6 will be installed
—> Package perl-Time-HiRes.x86_64 4:1.9721-144.el6 will be installed
—> Package perl-URI.noarch 0:1.40-2.el6 will be installed
—> Package perl-XML-Parser.x86_64 0:2.36-7.el6 will be installed
—> Package perl-libwww-perl.noarch 0:5.833-5.el6 will be installed
—> Package php-cli.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-common.x86_64 0:5.3.3-49.el6 will be installed
—> Package portreserve.x86_64 0:0.0.4-11.el6 will be installed
—> Package postgresql-libs.x86_64 0:8.4.20-7.el6 will be installed
—> Package ruby-libs.x86_64 0:1.8.7.374-5.el6 will be installed
–> Processing Dependency: libreadline.so.5()(64bit) for package: ruby-libs-1.8.7.374-5.el6.x86_64
—> Package ruby-rdoc.x86_64 0:1.8.7.374-5.el6 will be installed
–> Processing Dependency: ruby-irb = 1.8.7.374-5.el6 for package: ruby-rdoc-1.8.7.374-5.el6.x86_64
—> Package unixODBC.x86_64 0:2.2.14-14.el6 will be installed
—> Package compat-readline5.x86_64 0:5.2-17.1.el6 will be installed
—> Package krb5-devel.x86_64 0:1.10.3-65.el6 will be installed
–> Processing Dependency: libkadm5(x86-64) = 1.10.3-65.el6 for package: krb5-devel-1.10.3-65.el6.x86_64
–> Processing Dependency: libselinux-devel for package: krb5-devel-1.10.3-65.el6.x86_64
–> Processing Dependency: libcom_err-devel for package: krb5-devel-1.10.3-65.el6.x86_64
–> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.10.3-65.el6.x86_64
—> Package libproxy.x86_64 0:0.3.0-10.el6 will be installed
–> Processing Dependency: libproxy-python = 0.3.0-10.el6 for package: libproxy-0.3.0-10.el6.x86_64
–> Processing Dependency: libproxy-bin = 0.3.0-10.el6 for package: libproxy-0.3.0-10.el6.x86_64
—> Package lm_sensors-libs.x86_64 0:3.1.1-17.el6 will be installed
—> Package pakchois.x86_64 0:0.4-3.2.el6 will be installed
—> Package perl-Compress-Zlib.x86_64 0:2.021-144.el6 will be installed
–> Processing Dependency: perl(IO::Uncompress::Gunzip) >= 2.021 for package: perl-Compress-Zlib-2.021-144.el6.x86_64
–> Processing Dependency: perl(IO::Compress::Gzip::Constants) >= 2.021 for package: perl-Compress-Zlib-2.021-144.el6.x86_64
–> Processing Dependency: perl(IO::Compress::Gzip) >= 2.021 for package: perl-Compress-Zlib-2.021-144.el6.x86_64
–> Processing Dependency: perl(IO::Compress::Base::Common) >= 2.021 for package: perl-Compress-Zlib-2.021-144.el6.x86_64
–> Processing Dependency: perl(Compress::Raw::Zlib) >= 2.021 for package: perl-Compress-Zlib-2.021-144.el6.x86_64
—> Package perl-Crypt-OpenSSL-RSA.x86_64 0:0.25-10.1.el6 will be installed
–> Processing Dependency: perl(Crypt::OpenSSL::Random) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
–> Processing Dependency: perl(Crypt::OpenSSL::Bignum) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
—> Package perl-Digest-HMAC.noarch 0:1.01-22.el6 will be installed
–> Processing Dependency: perl(Digest::SHA1) for package: perl-Digest-HMAC-1.01-22.el6.noarch
—> Package perl-Digest-SHA.x86_64 1:5.47-144.el6 will be installed
—> Package perl-HTML-Tagset.noarch 0:3.20-4.el6 will be installed
—> Package perl-MailTools.noarch 0:2.04-4.el6 will be installed
–> Processing Dependency: perl(Date::Parse) for package: perl-MailTools-2.04-4.el6.noarch
–> Processing Dependency: perl(Date::Format) for package: perl-MailTools-2.04-4.el6.noarch
—> Package perl-Net-LibIDN.x86_64 0:0.12-3.el6 will be installed
—> Package perl-Net-SSLeay.x86_64 0:1.35-10.el6_8.1 will be installed
—> Package perl-Package-Constants.x86_64 1:0.02-144.el6 will be installed
—> Package perl-Socket6.x86_64 0:0.23-4.el6 will be installed
—> Package perl-Test-Harness.x86_64 0:3.17-144.el6 will be installed
—> Package perl-devel.x86_64 4:5.10.1-144.el6 will be installed
–> Processing Dependency: perl(ExtUtils::ParseXS) for package: 4:perl-devel-5.10.1-144.el6.x86_64
–> Processing Dependency: glibc-devel for package: 4:perl-devel-5.10.1-144.el6.x86_64
–> Processing Dependency: gdbm-devel for package: 4:perl-devel-5.10.1-144.el6.x86_64
–> Processing Dependency: db4-devel for package: 4:perl-devel-5.10.1-144.el6.x86_64
—> Package ruby-irb.x86_64 0:1.8.7.374-5.el6 will be installed
—> Package zlib-devel.x86_64 0:1.2.3-29.el6 will be installed
—> Package db4-devel.x86_64 0:4.7.25-22.el6 will be installed
–> Processing Dependency: db4-cxx = 4.7.25-22.el6 for package: db4-devel-4.7.25-22.el6.x86_64
–> Processing Dependency: libdb_cxx-4.7.so()(64bit) for package: db4-devel-4.7.25-22.el6.x86_64
—> Package gdbm-devel.x86_64 0:1.8.0-39.el6 will be installed
—> Package glibc-devel.x86_64 0:2.12-1.209.el6_9.1 will be installed
–> Processing Dependency: glibc-headers = 2.12-1.209.el6_9.1 for package: glibc-devel-2.12-1.209.el6_9.1.x86_64
–> Processing Dependency: glibc-headers for package: glibc-devel-2.12-1.209.el6_9.1.x86_64
—> Package keyutils-libs-devel.x86_64 0:1.4-5.el6 will be installed
—> Package libcom_err-devel.x86_64 0:1.41.12-23.el6 will be installed
—> Package libkadm5.x86_64 0:1.10.3-65.el6 will be installed
—> Package libproxy-bin.x86_64 0:0.3.0-10.el6 will be installed
—> Package libproxy-python.x86_64 0:0.3.0-10.el6 will be installed
—> Package libselinux-devel.x86_64 0:2.0.94-7.el6 will be installed
–> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-7.el6.x86_64
–> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-7.el6.x86_64
—> Package perl-Compress-Raw-Zlib.x86_64 1:2.021-144.el6 will be installed
—> Package perl-Crypt-OpenSSL-Bignum.x86_64 0:0.04-8.1.el6 will be installed
—> Package perl-Crypt-OpenSSL-Random.x86_64 0:0.04-9.1.el6 will be installed
—> Package perl-Digest-SHA1.x86_64 0:2.12-2.el6 will be installed
—> Package perl-ExtUtils-ParseXS.x86_64 1:2.2003.0-144.el6 will be installed
—> Package perl-IO-Compress-Base.x86_64 0:2.021-144.el6 will be installed
—> Package perl-IO-Compress-Zlib.x86_64 0:2.021-144.el6 will be installed
—> Package perl-TimeDate.noarch 1:1.16-13.el6 will be installed
—> Package db4-cxx.x86_64 0:4.7.25-22.el6 will be installed
—> Package glibc-headers.x86_64 0:2.12-1.209.el6_9.1 will be installed
–> Processing Dependency: kernel-headers >= 2.2.1 for package: glibc-headers-2.12-1.209.el6_9.1.x86_64
–> Processing Dependency: kernel-headers for package: glibc-headers-2.12-1.209.el6_9.1.x86_64
—> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
—> Package kernel-headers.x86_64 0:2.6.32-696.1.1.el6 will be installed
–> Processing Conflict: php56u-mbstring-5.6.30-2.ius.centos6.x86_64 conflicts php-mbstring < 5.6
–> Processing Conflict: php56u-xmlrpc-5.6.30-2.ius.centos6.x86_64 conflicts php-xmlrpc < 5.6
–> Processing Conflict: php56u-mysqlnd-5.6.30-2.ius.centos6.x86_64 conflicts php-mysql < 5.6
–> Processing Conflict: mysql57u-server-5.7.17-1.ius.centos6.x86_64 conflicts mysql-server < 5.7.17-1.ius.centos6
–> Processing Conflict: mysql57u-libs-5.7.17-1.ius.centos6.x86_64 conflicts mysql-libs < 5.7.17-1.ius.centos6
–> Processing Conflict: php56u-common-5.6.30-2.ius.centos6.x86_64 conflicts php-common < 5.6
–> Processing Conflict: mysql57u-5.7.17-1.ius.centos6.x86_64 conflicts mysql < 5.7.17-1.ius.centos6
–> Processing Conflict: php56u-gd-5.6.30-2.ius.centos6.x86_64 conflicts php-gd < 5.6
–> Processing Conflict: mysql57u-config-5.7.17-1.ius.centos6.x86_64 conflicts mysql-libs < 5.7.17-1.ius.centos6
–> Processing Conflict: php56u-xml-5.6.30-2.ius.centos6.x86_64 conflicts php-xml < 5.6
–> Processing Conflict: php56u-cli-5.6.30-2.ius.centos6.x86_64 conflicts php-cli < 5.6
–> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
FATAL - 2017-04-25 17:21:57 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2017-04-25 17:21:57 - Cannot continue installation.
FATAL - 2017-04-25 17:21:57 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2017-04-25 17:21:57 - re-attempted after any problems have been resolved.
FATAL - 2017-04-25 17:21:57 - Removing temporary directory and files.
FATAL - 2017-04-25 17:21:57 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2017-04-25 17:21:57 - in /root/virtualmin-install.log
