Fatal Error Occured: Something went wrong during installation
Howdy. I let my license lapse as I wasn’t active in web work so I re-upped it today, downloaded and ran the install script. I get a “Fatal Error Occured: Something went wrong during installation: 0”. It then says the clue to the issue might be in the log but I don’t see much of anything. What can I do to get this all fixed up?
Log attached:
INFO - 2012-08-07 03:40:43 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-08-07 03:40:43 - Install mode: full
DEBUG - 2012-08-07 03:40:43 - Product: Virtualmin Professional
DEBUG - 2012-08-07 03:40:43 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-08-07 03:40:43 - install.sh version: 1.0.9
INFO - 2012-08-07 03:40:43 - Checking for fully qualified hostname…
INFO - 2012-08-07 03:40:43 - Hostname OK: fully qualified as anteater.smokingflyback.com
INFO - 2012-08-07 03:40:43 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-08-07 03:40:43 - Loading OS selection library…
INFO - 2012-08-07 03:40:43 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-08-07 03:40:43 - Loading OS list…
INFO - 2012-08-07 03:40:43 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-08-07 03:40:43 - Operating system name: Debian Linux
INFO - 2012-08-07 03:40:43 - Operating system version: 6.0
INFO - 2012-08-07 03:40:43 - Configuring package manager for Debian Linux 6.0…
INFO - 2012-08-07 03:40:43 - Enabling universe repositories, if not already available…
INFO - 2012-08-07 03:40:43 - Disabling cdrom repositories…
INFO - 2012-08-07 03:40:45 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2012-08-07 03:40:45 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2012-08-07 03:40:45 - Installing Webmin and Virtualmin package signing keys…
INFO - 2012-08-07 03:40:46 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2012-08-07 03:40:46 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2012-08-07 03:40:46 - OK
INFO - 2012-08-07 03:40:46 - Ign
INFO - 2012-08-07 03:40:46 - Removing Debian standard Webmin package, if they exist…
INFO - 2012-08-07 03:40:46 - Removing Debian apache packages…
DEBUG - 2012-08-07 03:40:46 - Reading
INFO - 2012-08-07 03:40:46 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql
Reading package lists…
Building dependency tree…
Reading state information…
FATAL - 2012-08-07 03:40:48 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2012-08-07 03:40:48 - Cannot continue installation.
FATAL - 2012-08-07 03:40:48 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-08-07 03:40:48 - re-attempted after any problems have been resolved.
FATAL - 2012-08-07 03:40:48 - Removing temporary directory and files.
FATAL - 2012-08-07 03:40:48 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-08-07 03:40:48 - in /root/virtualmin-install.log
I recently applied your license renewal, as the license manager wasn’t able to do so automatically.
Could you try your installation again now? If it was related to the license being expired, it should work now.
Let us know how that goes!
