Each time I add a new domain to my Virtualmin server I get a failure error. Why is that happening and what can I do to resolve it?
Here is one that I just added and this is the error I’m receiving.
Requesting a certificate for dlkonlinelearning.com, www.dlkonlinelearning.com, mail.dlkonlinelearning.com, admin.dlkonlinelearning.com, webmail.dlkonlinelearning.com, autoconfig.dlkonlinelearning.com, autodiscover.dlkonlinelearning.com from Let’s Encrypt …
… request failed : Web-based validation failed : Failed to request certificate :
File “/usr/share/webmin/webmin/acme_tiny.py”, line 198, in
main(sys.argv[1:])
File “/usr/share/webmin/webmin/acme_tiny.py”, line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/share/webmin/webmin/acme_tiny.py”, line 149, in get_crt
raise ValueError(“Challenge did not pass for {0}: {1}”.format(domain, authorization))
ValueError: Challenge did not pass for autoconfig.dlkonlinelearning.com: {‘identifier’: {‘type’: ‘dns’, ‘value’: ‘autoconfig.dlkonlinelearning.com’}, ‘status’: ‘invalid’, ‘expires’: ‘2020-08-29T15:55:57Z’, ‘challenges’: [{‘type’: ‘http-01’, ‘status’: ‘invalid’, ‘error’: {‘type’: ‘urn:ietf:params:acme:error:unauthorized’, ‘detail’: ‘Invalid response from http://autoconfig.dlkonlinelearning.com/.well-known/acme-challenge/XCaI4TvyhKndOJSmBOQf2IAPsLUN_B0HhTeivhHWTGk [184.90.94.33]: “\n\n404 Not Found\n\n
Not Found
\n<p”’, ‘status’: 403}, ‘url’: ‘https://acme-v02.api.letsencrypt.org/acme/chall-v3/6704986210/ou3LWA’, ‘token’: ‘XCaI4TvyhKndOJSmBOQf2IAPsLUN_B0HhTeivhHWTGk’, ‘validationRecord’: [{‘url’: ‘http://autoconfig.dlkonlinelearning.com/.well-known/acme-challenge/XCaI4TvyhKndOJSmBOQf2IAPsLUN_B0HhTeivhHWTGk’, ‘hostname’: ‘autoconfig.dlkonlinelearning.com’, ‘port’: ‘80’, ‘addressesResolved’: [‘184.90.94.33’], ‘addressUsed’: ‘184.90.94.33’}]}]}, DNS-based validation failed : Neither DNS zone dlkonlinelearning.com or any of its sub-domains exist on this system
