I run an upgrade for 5 hours ago and it seems that Virtualmin failed to upgrade the usermin and webmin while all other packages such as apache where successfully upgraded.
Running CentOS 6.4 (64 bit)
Webmin ver: 1.620
Virtualmin ver: 3.99 Pro
Here is the log from usermin and webmin upgrade:
Now updating usermin …
Installing package(s) with command yum -y install usermin ..
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.ms5.eu
* extras: mirror.optimate-server.de
* updates: mirror.optimate-server.de
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package usermin.noarch 0:1.540-1 will be updated
---> Package usermin.noarch 0:1.550-1 will be an update
http://mirror.optimate-server.de/centos/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
http://centos.schlundtech.de/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.vieth-server.de/centos.org/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.softaculous.com/centos/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.halifax.rwth-aachen.de/centos/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.hosteurope.de/mirror/centos.org/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.informatik.hs-fulda.de/centos6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.jgotteswinter.com/centos/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://centos.mirror.linuxwerk.com/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
ftp://mirror.fraunhofer.de/centos.org/6.4/updates/x86_64/repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2: [Errno 14] PYCURL ERROR 19 - "Given file does not exist"
Error: failure: repodata/6cba1e6027e28d1b25e450e40633c5a98d71a2cc2482018b74bc87d6d7aedc20-filelists.sqlite.bz2 from updates: [Errno 256] No more mirrors to try.
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
.. install failed!
Now updating webmin …
Installing package(s) with command yum -y install webmin ..
---> Package webmin.noarch 0:1.620-1 will be updated
---> Package webmin.noarch 0:1.630-1 will be an update
.. install failed!
No packages were installed. Check the messages above for the cause of the error.
not sure what caused this issue…
Any idea ?
Thank You
Best regards
Amel
